After loading the x_t file from outside, Fusion measurements are opened in meters (m). There is no problem with other formats.Can you open the file yourself? What length will it open for you? I would like you to check it.
Solved by TrippyLighting. Go to Solution.
Solved by John_Wright. Go to Solution.
Solved by Phil.E. Go to Solution.
I'm surprised that you accept this situation as normal. Anyway, okay, I forgot about this problem.
