Unable to align body face to another's
obious
obious
Hi All,
I'm trying to align the face of a body (A) using face edge to pivot (B) to the face of another's (C & D) . I've tried both the Align and Move tools but so far have had no luck.
Anyone got any ideas?
TheCADWhisperer
@obious
Can you label Point A and B on the box component?
kacper.suchomski
Everything works for me
Kacper Suchomski
jhackney1972
@obious Is this what you want?  Does it have to be moveable, if so you need to create some components.  Model attached.
John Hackney, Retired
obious
@jhackney1972 @kacper.suchomski thanks for the responses, I should have been more clear that I don’t really want the object to move.
Maybe I could have done a better job at describing what I’m trying to do, but essentially I’d like to make the altitude faces of each body parallel with one another without moving either object
jhackney1972
What you describe you want is geometrically impossible.  One body MUST move, or change orientation, to become parallel to the other.  You can have them parallel to each other at some offset distance but one must move.
johnsonshiue
Hi! I believe you are looking to replacing the face so that it is aligned to the side. Replace Face in Modify panel should be the command to use. Please take a look at the attached f3d file.
Many thanks!
Software Test Engineer
