Closing simple profile - compute failed, curves do not precisely overlap
marksuperb_mj
marksuperb_mj
Hello, I am stuck at trying to close a profile in order to extrude outlines.
When trying to close body outline of a rooster's body (not head), compute fails - Failed to generate profile as, curves do not precisely overlap.
I left gap here.
Tried to search for solution, went through all the outlines if lines cross over each other, but with no luck.
Can someone help me solve this and tell me, where i made mistake, please? Thanks a lot.
TimelesslyTiredYouth
I feel really evil saying this, but I think the only way is to check over all the points and lines to see if there any miniscule gaps larger than 0.25mm or any overlapping lines. I do not think Fusion has any code it accepts to find these gaps like show.uncontrained however the only workaround I can think of is to create a sketch above the original one, and project each line one by one to see if they're not joined or overlapping, that may be quicker...
Just a few suggestions...
Ricky
marksuperb_mj
So i isolated problematic area which made this error. There was really subtle line crossing becuase of spline.
So, when i repaired that, freaking Fusion decided to just randomly break other part of sketch by moving randomly some line and deleting others ...
What's going on???
g-andresen
I copied the sketch into a new file and detected and closed an open vector with a dividing line.
günther
