Unable to add an appearance to a face
amirsamir92
Message 1 of 10
amirsamir92
I added an SVG on to a face and created a sketch based on that, I then used the "Split face" tool to create a face based on the sketch, I then dragged an appearance on to the face but nothing happens when I do that, I attached the file in case you might want to have a look at it
Screencast will be displayed here after you click Post.
Replies (9)
Message 2 of 10
sanket223.patil
I just figure out , you cant add appearance to that face . We can add appearance to that body , and other faces but not that face because of that image you added. If you want appearance , apply to whole body .
Sanket Patil
Mechanical Engineering
Expert Elite
Message 3 of 10
amirsamir92
Thank you very much, but that wasn't the face I was talking about, my screencast for some reason didn't show up in my previous post, please have a look at this screencast, I know that it can be done because I have done it before, but now it isn't working
Message 4 of 10
sanket223.patil
I am not able to see screencast.(PAGE COULD NOT FOUND).  Can you provide an image , so I can get the problem .
Sanket Patil
Expert Elite
Message 5 of 10
amirsamir92
[video]
Here is a video showing the issue, I did it before, it looked like the picture I added
Message 6 of 10
sanket223.patil
Sorry , Still not able to play video .    you can provide a image , and circle the faces in image where you are unable to add appearance .   I tried , I am able to add appearance to every face on that model . send me picture.
Are you trying to add appearance to that seven Icons , in which three are been given appearance ? I have also given them appearance , by zooming them little closer .
Sanket Patil
Expert Elite
Message 7 of 10
amirsamir92
Here is a link to a Youtube video showing the issue, https://youtu.be/jimkkfV9JgM, thank you very much for bearing with me
Message 8 of 10
sanket223.patil
Hello , Just figured out . there are two same bodies  , I think that's the reason face appearance is not applied . See the screencast .
iframe>
Sanket Patil
Expert Elite
Message 9 of 10
sanket223.patil
Are you able to see screencast above . I have inserted it . If not see this image below .  There are two bodies , i think that the problem . So I deleted the body circled with red and visible the body 1 in bodies . and apply the appearance . It works .split face issue ..JPG
Sanket Patil
Expert Elite
Message 10 of 10
amirsamir92
This works. Thank you so much! I wasn't able to see the screencast but the image helped, you have been very patient with me and I really appreciate it, thank you
