- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have a model that has a line recessed in with an angled line attached to it. If set to 90 degrees(where it will lay parallel with that line) I want the line to be 0.
I'm still working on the function for the bottom line however when the top value in the rectangle is set to 90 I want the bottom circled line to be 0.
With no functions or advanced stuff beyond my scope of knowledge it sits on top of that line. I want it to push out. Also having trouble being the one parameter is degrees and the other is mm.
The model will have an LED strip fit in that channel so it would need to stay wide enough to fit in when it's flush(not angled).
See the "Channel Profile" sketch in uploaded .f3d.
Thank you
¡Resuelto! Ir a solución.
