Hello, Im trying to create a folded sheet metal bracket that bolts to multiple point. Im having trouble as all the bolt holes are not flat. Does anyone have any ideas how I would create this. Thanks for your help
I recommend that you turn on Capture Design History and start over from scratch.
Attach your file with complete history here for help.
thanks I sent you the file that came from the 3d scanner. he has drawn these bodies from the scan. what I'm trying make is a L bracket that match to the holes with the correct angle. so both can bolt together
@haza27 wrote:thanks I sent you the file that came from the 3d scanner. he has drawn these bodies from the scan. what I'm trying make is a L bracket that match to the holes with the correct angle. so both can bolt together
Now I understand your Design Intent.
In the file, turn on Capture Design History.
Create New Component.
Do your best to model the L bracket and then Attach your attempt here.
I had a go, I found it hard to get the faces to line up with the correct angles
