Trying to create a sheet metal bracket from a Body. all different angles
8 REPLIES 8
Message 1 of 9
haza27
375 Views, 8 Replies
Hello, Im trying to create a folded sheet metal bracket that bolts to multiple point. Im having trouble as all the bolt holes are not flat. Does anyone have any ideas how I would create this. Thanks for your help mounting surfacesmounting surfacesmountain surfacesmountain surfacesbracket trying to createbracket trying to create
Labels (2)
8 REPLIES 8
Message 2 of 9
TheCADWhisperer
in reply to: haza27
Message 3 of 9
haza27
in reply to: haza27
Hello, thanks here is the export of the mounting surfaces
Message 4 of 9
haza27
in reply to: TheCADWhisperer
Hi, thanks, I have uploaded the file
Message 5 of 9
TheCADWhisperer
in reply to: haza27
I recommend that you turn on Capture Design History and start over from scratch.
Attach your file with complete history here for help.
Message 6 of 9
haza27
thanks I sent you the file that came from the 3d scanner. he has drawn these bodies from the scan. what I'm trying make is a L bracket that match to the holes with the correct angle. so both can bolt together
Message 7 of 9
TheCADWhisperer
in reply to: haza27
Now I understand your Design Intent.
In the file, turn on Capture Design History.
Create New Component.
Do your best to model the L bracket and then Attach your attempt here.
Message 8 of 9
TheCADWhisperer
in reply to: haza27
@haza27
Any progress on your attempt?
Message 9 of 9
haza27
I had a go, I found it hard to get the faces to line up with the correct angles
