Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Trouble with sketching shape (arc command)
2 REPLIES 2
cmuellerFNYDZ
204 Views, 2 Replies
I am a Fusion 360 beginner (and first time posting to this forum) and I found this exercise book online. I am having trouble making the 4 arcs between the two circles. I inserted a screenshot of the exercise book page and below it the work I have done so far in fusion. The red line shows which arc I am talking about. If anyone can help me that would be much appreciated.
2 REPLIES 2
davebYYPCU
in reply to: cmuellerFNYDZ
Sketch (1) 3 point arc, or circle, in the sort of correct position,
using Tangent constraint, make that arc or circle, tangent to the other two known, connections,
that done trim the excess if you wish.  You will need a radius to finish it off.
That exercise should sketch 1/4, and then mirror the body twice.
Might help....
Technology Administrators
