Hi everyone,
When I create a new sub-component, the created origin of the new component will be at the same location as the origin of the main component. I want to have the origin of the new component (which I create in a top-down modelling way) to be at a different location. I want this to prevent origins of new components to be far away from their body. I cannot figure out how to do this.
Attached a screengrab. Below, the origin of the new part "box holder". Near the sketch of the box holder (the rectangle) I created a "joint origin" to indicate where I want the origin of the "box holder" to be.
Thanks you for your help.
Solved by TrippyLighting. Go to Solution.
please share your design.
File > export > save as f3d on local device > attach to next post
günther
Hi Guenther,
Thank you for your help. Attached the example file.
-Dan
In Fusion 360, while there is somewhat of a workaround, you cannot do this after the fact, meaning after you've started creating anything in that componet.
You can, however , create a new/empty componet and then assemble the origin of that component to the desired location with a joint. Then you can start creating sketches and 3D geoemetry in the component.
It's a little clunky, but it works.
Hi TrippyLighting,
Thank you for your help!
That's unfortunate. But now I know better how I should build up my models. Thanks!
Kind regards,
Dan
