Can I calculate or simulate how much force goes in to a movement? (models attached)
I'm working on a couple of ideas on how to force plastic endings in metal tubes. I have some fully automated ideas and some different presses but this version that builds on a mechanical excenter is my latest idea. Im thinking it could both be used manually with a arm or it could be connected to a motor and be driven that way..
However, some plastic tube endings are a really tight fit so I really need to make sure a excenter design would work.
My main model attached in this post: "excenterPress"
Can I simulate how heavy the plastic ending is to push? And from that get a read on how much force is needed to turn the axle?
If not, is there another way to calculate it?
And, if its way to heavy, what would be the next step to make it less heavy to turn? Gears? another excenter wheel?
My second model attached in this post: "exenterTest v1"
(This is a different question but related cause of the excenter problems)
One thing I have noticed about excenter designs is that they can fool you. The model is a dummy version I made for this post showing a type of excenter design I have been working on improve right before the holidays. The big curve that pushes the object is the variable that can be changed to get difference in how heavy the axle feels to move. I had to do a couple of different prototypes and test since I don't know the math behind it..
