Title block attributes
sstephe1622
1.591Aufrufe
16Antworten
Nachricht 1 von 17
sstephe1622
With the May update, is there any way to use part description, material etc.
0 „Gefällt mir“-Angaben
Akzeptierte Lösungen (1)
1.592Aufrufe
16Antworten
Antworten (16)
Nachricht 2 von 17
jhackney1972
Akzeptierte Lösung
If you are thinking about attributes that "automatically" read the model properties then the answer is NO.
John Hackney, Retired
Nachricht 3 von 17
mika.takalo
https://help.autodesk.com/view/fusion360/ENU/?guid=GUID-B0A4BEF9-5DBB-4843-9D5B-EE080CCFD9E7
Where is this "contextual environment" now?
Where in the part properties we can find all those lines to fill, which attributes are as a default in title block?
Nachricht 4 von 17
g-andresen
These are the automatically generated entries.
Everything else you can create individually!
günther
Nachricht 5 von 17
mika.takalo
Individually adding means manual adding? Not part attributes from 3D model?
Nachricht 6 von 17
jcbyrd24
Hi there I'm a new user and am trying to figure out revisions and title blocks. This thread and info published by Autodesk seem to suggest that previously the titleblock "Attibutes" could be edited in a contextual environment, but that now seems to be gone. I can see the stock title block autopopulating some info but I can't figure out how to edit it so I don't have to type manually the information into every sheet. When I right click and select edit title block the New Title Block Dialog opens and I can't do anything to the text size/attributes/etc.
Nachricht 7 von 17
jhackney1972
You seem to be asking two different questions. One, to edit an attribute already in the title block and Two, how to create an attribute in a title block.  I hope the video will help.  I can into more depth is you need.
Nachricht 8 von 17
jhackney1972
Sorry, I accidentally had my mic off on the last video, try this one.
Nachricht 9 von 17
jcbyrd24
Thank you so much. I got deterred by the "New Titleblock" heading and was in fact 1-click away from the Editing environment. That works fine now.
So more accurately for the 2nd part of my question. Where do I go to edit those attributes that are supposed to automatically import from the model. If I click on them in the Titleblock Edit environment it converts them to Custom attributes. I can't find in the model where to edit these attributes.
Nachricht 10 von 17
jhackney1972
The video will explain how to add a Model Attribute and then Fill it in.
By the way, even though this Forum post has an Accept Solution status, please select it for my solution if it meets your requirements.  This will flag it for others looking for a similar solution.
Nachricht 11 von 17
shardwickVFJD6
Community Visitor
Community Visitor
@jhackney1972 would there be any reason as to why it doesn't work as easy as the video??
I have tried multiple times to either change the existing attribute or add a new attribute to auto fill the part name and part number, but no luck.
My BOM has the part number and name auto filled, but for the life of me I cannot get the title block to update accordingly.
Nachricht 12 von 17
jhackney1972
My guess is that your are forgetting to Save your model so the attribute is carried into the 2D Drawing.  What I suggest you do is tell me what Attribute you want to show up in your Title Block and attach your model, not drawing, and I will create the attribute you want in my drawing to show the process.  Remember to tell me what specific attribute you want.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
Nachricht 13 von 17
shardwickVFJD6
Community Visitor
Community Visitor
I wish it was as easy as just saving, but at last I have saved and relinked the CAD model several times to no prevail.
I am just trying to change the stock title block attributes of Title_1 to Model_Part_Name and change the DWG_No to Model_Part_Number. Easy enough, so I thought.
Nachricht 14 von 17
jhackney1972
I created a new title block in a new template, using the attributes you wanted, save it and created a new drawing of one of my models.  It works just fine.  Created a drawing, using the same template, of your model and it will not populate the fields.  I saved your model out as a new file and it still will not populate the title block although all my models work perfectly with the new template.  I have nothing to offer except to refer it to the Autodesk 2D Drawing guru.
@ClintBrown3D , can you explain this one for us?  This is an old thread but the model Access Ladder V10.f3d, shown in the previous post is the problem.  Thanks
Nachricht 15 von 17
ClintBrown3D
Hi @jhackney1972
The team is working on this issue. While we wait for a fix, it might be best to re-insert those attributes in the title block ans re-save the template. Hopefully we'll have a fix soon.
cc: @Pramod.kadam
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Nachricht 16 von 17
danG8FEK
I have been wrestling with this for the past couple days as well. Hopefully you are able to figure out what is going on. I tried making a new title block and template but it still won't pull information from the model. However the information gets pulled for tables. I also went back and checked an old drawing to see if it was doing the same thing. Answer is yes. When I opened the drawing the material and part names were there but the moment I refreshed the properties in the title block they disappeared. Looks like it will have to be manual entry for now. I know this isn't a solution but wanted to chime in so people don't think it is only them.
Nachricht 17 von 17
mabaker33
John,
Thank you for the information on properties and their operations. Having driven Inventor for 20 years, I figured attributes and properties were similar, but I was not clear on the auto-population from model to title block.
Thanks for the help
Mike Baker
