textures for 3D printing
Is there a way to add textures with Fusion 360? Magics has a plugin that can do the same thing
https://www.materialise.com/en/software/solutions-for-design/textures-patterns-perforations
And this python script seems like a good approach (https://github.com/hanskellner/Fusion360Image2Surface) but the image I have to start with is not perfect
lucasliraAU
Hi @Anonymous
Thanks for reaching out to us on the forums!
I do not know an automatic process for adding textures on a surface for the 3D printing process on the Fusion 360 platform.
What I take into consideration is the creation of textures by the manual process be it in the process of thinning the CNC process with the integration of CAM.
Or manual creation.
There are some videos that you can follow.
I hope this can help your work!
Did you find this reply helpful ? If so please use the Accept as Solution or LIKES button below.
Si esta respuesta te ha servido de ayuda, por favor márcala como Solución Aceptada o dale a LIKES
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
