hi rocmen here newbie ? i want to cut letters out of a foam (board 12"x12" x 1")
i can't find a video can u help
thanks rocmen
Solved by etfrench. Go to Solution.
Can you Export your *.f3d attempt to you local drive and then Attach the file here?
i don't know what that means i am in sketch trying to cut letters ABC out how do i draw it up in cad then toolpath it so i can cut it with my cnc router i am new
thanks rocmen
@Anonymous wrote:
i don't know what that means ....
In the upper left corner of your screen click the down arrow next to page symbol and then select Export....
Give your file a Name.
Pay attention to where on Save to my computer the file is being exported.
Reply to this post.
Click Attach and browse to the location of the exported file.
Click Post.
Clear as mud?
Your question is so basic that it indicates you haven't gone through the learning videos. https://help.autodesk.com/view/fusion360/ENU/
Basic workflow:
ETFrench
Which part of the workflow I posted are you stuck on? Have you gone through the fundamental learning videos?
ETFrench
@Anonymous look at the top of the forum support & learning
Thanks that helped alot i am going through the basics with Lars Christensen his videos are good learning alot
thanks Rocmen
i followed along with the video ? on the cam tab change mm to inch will not change on the drawing its inches
also 2d contour select says nothing on the chain button does nothing when i push it
also i don't have the main tool library
that's a lot thanks rocmen
CAM and Model workspace units are separate. My CNC is setup for inches, but most of my modeling is done in metric.
The contour select button doesn't do anything. It shows how many contours are selected (by clicking on the individual contours).
You need to create your personal libraries to match the tool bits you have. The easiest way is to copy a sample tool into a library you create.
ETFrench
