- Mute
- Permalink
- Report
I am attempting to apply a moulded pattern to the curved surface of a cylinder and repeat all over.
Flat Moulded Pattern
I am using the project to surface tool to create a path that I want to sweep with. When using the sweep tool the resulting body does not line up in some corners correctly. See attached screenshot.
Pattern applied to curved surface
I have tried using a guide rail but the tool will not generate. I have used lofting with rails and this does not result in the desired shape.
I have tried many options, including cutting a body to create the outline, sweep following a surface (which did not generate) and attempting to convert a flat variant of the shape into a t-spline but the body is too complex.
How can this be resolved?
