Sweep with cube instead of sketch (or workaround)
Message 1 of 29
Hi, I'm trying to create an object that the equivalent of "sweeping" a cube in a straight line along one of its natural axis with a 45 degree rotation. I've tried sweeping the front and back face separately, but I can't sweep the 4 remaining sides as it's perpendicular to the sweep path. Is there another approach to this?
Accepted solutions (4)
Replies (28)
Message 2 of 29
g-andresen
please show the process in a screencast and share your design.
günther
Message 3 of 29
Marco.Takx
Hi @Anonymous,
Like @g-andresen  said, without seeing your design it is hard to help you with an answer.
Within Fusion 360, choose File > Export and save it on your desktop.
After that upload it to this topic so that one of us can take a look at it.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 4 of 29
Hi Marco, I've included a video animation showing the cube motion that I'd like to form into an object.
Message 5 of 29
Hi @Marco.Takx,
I've attached my Fusion 360 project archive below with my attempt. Would you be able to help me?
Message 6 of 29
Marco.Takx
Hi @Anonymous,
Is this where you are after?
Within the Combine feature, I choose Cut.
A real solid sweep isn't available within Fusion 360.
This is available within Inventor.
Marco Takx
Message 7 of 29
davebYYPCU
Like this?
Message 8 of 29
TheCADWhisperer
Do you have a picture of something similar that already exists in the real world?
Message 9 of 29
Hi @Marco.Takx , not quite, I would most definitely like to have the sweeps combined as if one cube was used to perform the sweep.
Message 10 of 29
Hi @davebYYPCU , yes, something like that. The idea is that I will subtract that object from a box so that a die (singular of "dice") can slide through it, twisting in a tunnel.
Message 11 of 29
davebYYPCU
Then it is a normal Sweep, with profile and clearance to allow that.
Message 12 of 29
@TheCADWhisperer It's really close, but as mentioned in another reply, the intention is to invert it, so that the shape is a void, so that when 3D printed, I could have a die (singular of "dice") slide down it, twisting 45 degrees. With a tight tolerance, it would get stuck at the ends
Message 13 of 29
TheCADWhisperer
Are you a student?
If so, you can use Autodesk Inventor Professional for this Sweep (cut) Solid.
Message 14 of 29
Thanks @davebYYPCU , although it's not a perfect solution, it's the best option it seems given the available tools in Fusion 360
Message 15 of 29
TheCADWhisperer
Attach your "solution" here.
Message 16 of 29
chrisplyler
From your animation, I believe you seek to have one of the edges remain colinear to itself throughout the length of travel. If that is correct, I believe this is the general shape of the geometry you seek.
I did it with a convoluted process of sketches (including capturing the edges of a couple of coils) and surface sweeps.
Message 17 of 29
Hi @chrisplyler , the axis the cube is translated along and rotated about is perpendicular to two of the faces, and parallel to the other 4 faces, so I cannot perform a sweep with them
Message 18 of 29
MRWakefield
Is this the kind of thing you're looking for? I've assumed a 20mm cube and given it 0.5mm clearance all round. You'll find I've also modelled the 20mm cube half way down the tunnel.
I'm sure someone else could come up with something more elegant but I think this will do what you want.
I hope this helps.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Message 19 of 29
davebYYPCU
Then the animation has sent us down the wrong track.
This will be solved when we get some dimensions.
We know the 45 degree bit,
What size is the dice?
What size is the axis length of material for the twisted tube?
Message 20 of 29
davebYYPCU
Adding sufficient clearance to the profile, it’s a simple sweep, I was picturing your example with just more wriggle room, no need for the double sweep.
Length of the tube drives how much clearance.
