Adding "Countersink" feature to hole created in Eagle then exported to Fusion
philiprochester
Message 1 of 1
philiprochester
Hi everyone, so I have imported a PCB from Eagle with a through hole already drilled in the PCB. The issue is, in Eagle it is not possible to add a countersink hole. So I need to add the countersink hole feature to the hole which is already existing in the imported model (Eagle to Fusion Import).
I tried to use the hole command in Fusion, as well as the chamfer command but these don't seem to select the point of an existing hole. What are the necessary steps I need to take in Fusion to add a countersink hole feature to the existing hole in my Eagle design?
Thanks in advance.
Philip
Replies (0)
