Sweep/Sketch Issues
Sweep/Sketch Issues
Message 1 of 16
Sweep/Sketch Issues
1 - I am very new to the sweep feature and am trying to add it to my bag of tricks in fusion. I drew a profile id like to sweep around an edge of a body to create a new body which produced a result but not quite what Im looking for. It wont maintain the original relation so I need some help as to where Im messing up. https://share.getcloudapp.com/rRukbn1X
2 - I run into issues alot when I try to use body profile to have a perfect reference on a new relative sketch. For instance when I offset or project geometry from a body and then try to extend or trim for example I will get errors referencing constraints and or dimensions being removed and its frustrating. I know could create a close replica from scratch with using the profile as a guide but it wont a perfect reference and I've got to believe there's a more efficient way to go about it. Perhaps its something that I can easily fix that I don't understand. https://share.getcloudapp.com/E0u9jPpd
Here's how I started trying to achieve this sweep instead of a different workflow - https://share.getcloudapp.com/DOu2Bvk5
As always the input is much appreciated ! - JD
Replies (15)
Message 2 of 16
g-andresen
1. Please embed images directly into the text using the forum tools (camera icon).
This avoids unnecessary clicking between text and images.
Links to unknown sources are not suitable.
2. Unfortunately, there is no indication of affected elements in your file. Even the crystal ball does not help.
günther
Message 3 of 16
So the video links dont work or you dont want to watch them that way?
Message 4 of 16
davebYYPCU
They don’t load to be viewed - that way.
Message 5 of 16
Strange, I get notifications every time someone views them and haven't had a complaint yet but I'll try and edit the post I guess
Message 6 of 16
laughingcreek
I watched them.  not a chance a sweep will work, the shape isn't consistent around the part.
not entirely sure what your trying to end up with , but look at the attached and see if gets you close.
Message 7 of 16
I'm really confused with a response of "No chance a sweep will work because its not consistent." Could you elaborate on that please? To make a sweep You're creating a 2D shape and telling it to follow a path. What part of that equation makes a sweep not possible in my file?
Message 8 of 16
laughingcreek
sweep will sweep the same (ie consistent) profile around a part.  the cross section of the profile you need changes as it goes around the part.
also, 3d sweeps are really hard to get right in fusion
the original part looks to have been made with a series of offset faces based on the outer shell and the curve used to cut it in half, not a sweep.  that process can be recreated, but what I did in the previously attached file is probably faster
Message 9 of 16
I think I must be miscommunicating because we're not talking about the same thing. I am trying to sweep a 2d sketch around a path on the object using a singular edge that has nothing to do with the profiles you're pointing out in the pictures.
Message 10 of 16
Im sorry I keep trying to attach a screencast and its not working. starting to get frustrated so Im going to give you the links again.
https://share.getcloudapp.com/KouZJ7gx
https://share.getcloudapp.com/12uovPGm
Message 11 of 16
Here is a new screencast using the auto desk recorder
Message 12 of 16
laughingcreek
yes. sweeps sweep a 2d profile. always.  but if the path isn't planer, it's a 3d sweep.  3d sweeps are funky in fusion.  it's also the wrong tool for this case becuase it would produce a shape that won't fit in the groove.
did you have a chance to look at the model I posted earlier?
Message 13 of 16
laughingcreek
you can copy/paste (ctrl-c, ctrl-v) pictures straight into the forum.  or you can do it using this-
screencasts are another matter.  the insert screencast tool at the bottom of the post is broken/non-functioning most of the time.  been that way as long as I can remember.  from the screencast site you can copy the html for it by clicking embed-
and then back on the forum reply click on the HTML button and paste the code in-
and the screen cast will show up in the body of the post
Message 14 of 16
Yes that file you attached earlier got the desired result thank you. However I'm not sure how you got there because I'm not very familiar with the patch/surface commands so I guess ill have to try and figure out that workflow to apply in other situations. I watched some 3d sweeps on you tube and got excited which is why I was trying to apply here. Also I see now that the profile changes along its patch somehow which was an oversight and should probably revisit to re-work that groove. Thanks for all your help its very much appreciated!!
Message 15 of 16
laughingcreek
as long as the cross cut is an ogee,  I don't see how you would get the groove to not change as it goes around.  as is it's a pretty nice design, I wouldn't think you would want to change it.
It looks like it was made with surfacing techniques.  putting the groove in any other way will be challenging. (unless you change to a planer cross cut normal to the centerline, which would be boring)
Message 16 of 16
g-andresen
This is what I meant.
günther
