Sweep/Sketch Issues
- Mute
- Permalink
- Report
1 - I am very new to the sweep feature and am trying to add it to my bag of tricks in fusion. I drew a profile id like to sweep around an edge of a body to create a new body which produced a result but not quite what Im looking for. It wont maintain the original relation so I need some help as to where Im messing up. https://share.getcloudapp.com/rRukbn1X
2 - I run into issues alot when I try to use body profile to have a perfect reference on a new relative sketch. For instance when I offset or project geometry from a body and then try to extend or trim for example I will get errors referencing constraints and or dimensions being removed and its frustrating. I know could create a close replica from scratch with using the profile as a guide but it wont a perfect reference and I've got to believe there's a more efficient way to go about it. Perhaps its something that I can easily fix that I don't understand. https://share.getcloudapp.com/E0u9jPpd
Here's how I started trying to achieve this sweep instead of a different workflow - https://share.getcloudapp.com/DOu2Bvk5
As always the input is much appreciated ! - JD
