Sketch Copy Command
Sketch Copy Command
KLathwell
Message 1 of 11
Sketch Copy Command
KLathwell
Hi Guys
I have some issues when copying Sketches and constraints.
I am posting my very first Screen cast so I hope things explains my problem
Replies (10)
Message 2 of 11
jeff_strater
your screencast did not make it to your post. Make sure you click on Insert to actually insert the screencast into your post.
Jeff Strater
Engineering Director
Message 3 of 11
KLathwell
Thanks Jeff
So we can try again.
However Screen Cast doe snot regognize my URL
https://knowledge.autodesk.com/community/screencast/d1b9aea1-1484-4df6-a902-77902dea3568
Message 4 of 11
g-andresen
In your screencast, unfortunately, you can't see the relationship of the sketch in the design.
Please share the file.
File > export > save as f3d on local device  > attach it to the next post.
günther
Message 5 of 11
davebYYPCU
Your tick copy then move is correct.
It is no longer constrained to the origin, as it is a copy.
Make the window articles from first sketch and then copy pattern the component.
Sketch patterns are not recommended.
Might help....
Message 6 of 11
KLathwell
Hi Dave.
So my sketch copy was correct but I am not sure regarding you second comment. Are you saying that the correct way is to make the one sketch, make the component and then copy the component -,
For some reason I cannot get the screencast to insert so here are the 2 URL
https://autode.sk/2ZpFyOd
Message 7 of 11
davebYYPCU
Absolutely.
You make the window, component / assembly.  Pattern them.
Sketch patterns are looking for all constraints to be repeated, for every article within them.
further, if you do copy / pattern the sketch, then you will be making a set of body processes repeatedly, from each of those sketches.
Might help...
Message 8 of 11
shahriarsifat1802164
Can you please share your project so that we can collaborate?
Thank you.
Md. Shahriar Mohtasim
Dept. of Mechanical Engineering,
RUET
LinkedIn | Facebook | Youtube (CADs) | Twitter
Autodesk Product Users, BD
If you found this post helpful please hit the LIKE button and for a solution hit the ACCEPT SOLUTION.
Thank you.
Message 9 of 11
KLathwell
Hi Shahriar
Were you able to access the link I sent in my earlier post
Message 10 of 11
KLathwell
Hi Dave
Sorry to be so dumb, what are to sating when you say Pattern them
Message 11 of 11
g-andresen
@KLathwell wrote:
... what are to sating when you say Pattern them
1. watch the screencast.
2. patterns can be made in both sketch mode and body mode.
günther
