svg scale and cleanup
wanting to scale svg file to base plate of a specified size . Also svg coming in without crisp lines
innovatenate
Autodesk Support
Autodesk Support
You should be able to use the scale command from the Modify menu to select the sketch in the browser or use the scale command in the Insert SVG dialog. Perhaps one of these links will help also:
https://www.youtube.com/watch?v=2kDEQVQVkl8
https://knowledge.autodesk.com/community/screencast/0b90cd27-349b-4057-b7ef-388a880ba77b
http://forums.autodesk.com/t5/design-validate-document/dimension-accurate-svg-import/td-p/4823275
https://forums.autodesk.com/t5/design-validate-document/scale-for-sketch-when-importing-svg-files/td...
I hope those help!
Nathan Chandler
Principal Specialist
Thank you , I will watch those and try it out
