SVG position driven by parameters
I'm trying to place an SVG (a logo) on a flat surface and control its position on that surface via a parameter. I would like the corner of the sketch to be positioned at a point relative to the side of the surface
In the attached image, the origin of both sketches is the same as the design origin. I want the four shapes (Sketch 1) to stay in the same position relative to each other but move relative to the rectangle (Sketch 2). If I could drive the origin of the Sketch 1 based on geometry that would work. If I try to drive the contents of the sketch they move separately and I can't figure out how to make them move together.
g-andresen
maybe this will help?
position sketchposition sketch
günther
laughingcreek
put the sketch in a component.  you'll will import just once.  copy the component 3 more times.  position by jointing to a dimension-ed sketch at the top level.
this will seem weird if your new to components. a face palm if your not.
That makes total sense. Thanks!
elf_monkey
Sir. for what do you need copy 3 times?
Fusion won't let me use joints with an imnported svg component
IT SAYS THEY ARE RIGIDLY JOINED
g-andresen
Perhaps the component was fixed when it was inserted using the new "Ground to parent" function.
Have a look at this Tutorial
Maybe unground it:  rightclick > unground
günther
