Stuck uploads.
Stuck uploads.
Stuck uploads.
Hi I am Asutosh, I have selected a .step file to upload yesterday. It still uploading. How to cancel this uploading process.
James.Youmatz
Autodesk Support
Autodesk Support
 Hi @Anonymous,
You will have to perform these steps in order to manually clear the upload dialog box:
  1. Close Fusion 360
  2. Browse to the following directories
  3. Windows: C:\Users\%USERNAME%\AppData\Local\Autodesk\production\JobManager360\<Most Current Application ID (sort by date if mutlple)>\
  4. Mac:C:\Users\%USERNAME%\Library\Application Support\Autodesk\production\JobManager360\<Most Current Application ID (sort by date if mutlple)>\
  5. Locate the jobs.json and the jobs.json.lck files.
  6. Delete both the json and the lck file.
  7. Restart Fusion 360 and review the Upload queue.
If this solves the issue you were having, feel free to accept this answer as a solution. Otherwise, let me know and I will try my best to help resolve the issue further!
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
I was just wondering if you had a chance to try out the suggestion I gave you? If that suggestion worked for you, feel free to mark that answer as a solution so that others can benefit from this thread. If you have any more questions, let me know and I'd be more than happy to answer them!
James Youmatz
Hi James
There is no "App Data" folder and "Fusion 360" in my User folder, so I
am unable to find and
delete the process file. Please do suggest, If there is another solution.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Do you have hidden files and folders turned on? The folder "AppData" is a hidden folder.
To enable hidden folders for Windows:
  1. Open Control Panel
  2. Click Appearance and Personalization
  3. Click Folder Options
  4. Click the View tab
  5. Enable "Show hidden files, folders, and drives."
Please let me know if this solved the issue. If not, I will work with you further to help clear your upload queue.
James Youmatz
It worked..Smiley Happy
James.Youmatz
Autodesk Support
Autodesk Support
Not a problem. Glad I could help!
James Youmatz
