Stuck at 80% Generating Mesh
I am currently trying to run a simulation on a model that I have created but when generating the mesh for the simulation, the mesh gets stuck at 80% complete and goes no further.  Are there any work arounds to fix this issue?
Please find .f3d file attached below for reference.
innovatenate
Autodesk Support
Autodesk Support
There are some geometry errors. The Patch > Inspect > Validate command catches the errors. The "translucent" faces in the design give away some clue that there are some geometry errors.
You can use the Boundary Fill Command to generate a new solid body from the existing geometry. The resulting body generates a mesh quite nicely in the simulation environment.
See the below screencast and attached design for details.
I hope that helps!
Nathan Chandler
Principal Specialist
matteoFLC6B
Observer
Observer
How do you get into "THE PATCH" mode.
The options I see are:
"Design, Generative Design, Render, Animation, Simulation, Manufacture, Drawing"
