Message 1 of 10
how do i make a hole through the bottom of them pod? i cant seem to figure it out.
You need to specify a little more information. What size square hole, through what components or bodies?
John Hackney, Retired
2mm wide Square hole through the pod design, through Top And Bottom of body, sorry for bad explenation. i posted a pic showing it, also wondering how do you curve the body from all sides ? thanks!
I am still not sure what you exactly want but I will take a stab at it. The model is attached and a screen capture below.
thank you for helping! i figured it out i need to click faces i want to hull.. rookie mistakes. if you wanna show me how to curve the body on all sides that would be great too!
You are very unclear on your needs. What do you mean "curve the body on all sides"?
i posted a picture showing: so all 4 faces z-x i want them to be Curved, i dont know how to explain it any better
try a sweep-
thank you so much! i have another question hope its ok, so im trying to make 4 flat holes but i cut through the body how do i make the body thicker on the bottom and thinner on top? i attached a photo the holes in the body are not supposed to be there.
thank you for your time, i figured it out i can angle the holes im extruding to make it flat and not make a hole through the bodies wall.
