Square hole through all
oystein.l.l
Message 1 of 10
oystein.l.l
how do i make a hole through the bottom of them pod? i cant seem to figure it out.
Replies (9)
Message 2 of 10
jhackney1972
You need to specify a little more information.  What size square hole, through what components or bodies?
John Hackney, Retired
Message 3 of 10
oystein.l.l
2mm wide Square hole through the pod design, through Top And Bottom of body, sorry for bad explenation. i posted a pic showing it, also wondering how do you curve the body from all sides ? thanks!
Message 4 of 10
jhackney1972
I am still not sure what you exactly want but I will take a stab at it.  The model is attached and a screen capture below.
Message 5 of 10
oystein.l.l
thank you for helping! i figured it out i need to click faces i want to hull.. rookie mistakes. if you wanna show me how to curve the body on all sides that would be great too!
Message 6 of 10
jhackney1972
You are very unclear on your needs.  What do you mean "curve the body on all sides"?
Message 7 of 10
oystein.l.l
i posted a picture showing: so all 4 faces z-x i want them to be Curved, i dont know how to explain it any better
Message 8 of 10
laughingcreek
try a sweep-
Message 9 of 10
oystein.l.l
thank you so much! i have another question hope its ok, so im trying to make 4 flat holes but i cut through the body how do i make the body thicker on the bottom and thinner on top? i attached a photo the holes in the body are not supposed to be there.
Message 10 of 10
oystein.l.l
thank you for your time, i figured it out i can angle the holes im extruding to make it flat and not make a hole through the bodies wall.
