Modelling a Multi Angled Lofted Object and Mapping a Surface to It
Hi There,
I'm looking for some advice with regards to a small personal project, I am struggling to proceed with developing a model of a local landmark and subsequently mapping the plates it is constructed from.
This is the building in question:
In my mind, the model is a simple multi-lofted design that can be extruded with a couple of sketches on custom angled plains. The issue comes with modelling the triangular plates which have been used in the construction. I've attempted to use projected extrusions which are then path patterned with the loft sketch as a path. While this aesthetically works with a simple loft, due to the curvature of some lofts, the extrusions deform which does not work for my intentions (to 3D print a representation).
I am looking for a better way to model and feature a design based on the above landmark and to avoid the pit falls of my current process (when I eventually model other landmarks for fun!).
Cheers
