I have a simple assembly to which I am applying joints so I can observe it's movement when moving the feet. I have applied rigid joints to connect the legs and feet. There is a rotational joint in the center pivot and I applied a rotational joint to the left foot and the Y-axis. What I am unable to do is constrain the right foot to slide on the X-axis. Is this possible to do with a joint or I am I looking at this the wrong way. I eventually like to observe how movement changes with various geometry changes to the components.
