Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Splitting a line with Driven Dimension length into segments
Message 1 of 8
Hey guys,
I'm having a line which length is determined by other constraints / dimensions. I'd like to split the line into two parts so that I have a 2:1 ratio.
I thought it might be possible to use the driven dimension length between the start and end point as in "d40/3" but d40 (which is shown when hovering over the dimension) is not recognized as parameter and stays red.
Is it possible to do that somehow?
Replies (7)
Message 2 of 8
HughesTooling
Can you attach some screen grabs or export the file and attach. You are not trying to reference the d40 dimension to it's self eg. d40:100 and in the d40 dimension you're entering d40/3, because that will not work.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 8
Of course. And no - I didn't try to use the dimension of a line to calculate a different length of the same line. 🙂
The original sketch is a little more complex, but this is enough to see what I mean:
The triangle is defined by three parameters. Vertical length, horizontal length and the angle.
This makes the top line a "Driven Dimension" named d58. I'm trying to use a construction line on that top line to position the center of the circle at d58/3:
d58 is also not listed on the "parameters" page.
Message 4 of 8
HughesTooling
I understand now. Driven dimensions are only for reference at the moment their parameters are not available to use in other parameters or dimension.
Mark
Mark Hughes
Message 5 of 8
How would I make a feature request out of this? 🙂
I'm a beginner with CAD, but it felt really natural to work that way, especially since the Driven Dimension also seems to have a placeholder name internally.
Message 6 of 8
HughesTooling
It has come up before and I think there might be a request on the Ideastation. Your only option at the moment would be to use trig and calculate the length in a user parameter. Here's a link to help on what functions are available in parameters.
Mark
Mark Hughes
Message 7 of 8
HughesTooling
Here's a link to a request on Ideastation.
Mark
Mark Hughes
Message 8 of 8
I had the trigonometric idea while playing with the "simplified example" above. Thanks for pointing me to the functions list.
Still in my more complex design d40 would be a lot easier than
( sqrt(( ( ( sensor_height * 2 - spacing * 2 - shield_wall ) * tan(90 deg - shield_angle) / 1 mm ) ^ 2 ) + ( ( sensor_height * 2 - spacing * 2 - shield_wall ) / 1 mm ) ^ 2) ) * 1 mm
But at least I can add a line to test the calculation first... 😉
