import svg files created in OpenOffice Draw
Hello, I am creating sketches to be used a blades to cut solid blocks for complicated profiles designing (with splines). OpenOffice allows me to create and export without problem. When I import into 123d, the sketch is huge and cannot be selected as whole to be resized, moved or rotated.
Does anyone has a clue or a solution, or do I have to create my sketches directly in 123d ?
Thank's in advance
Maowen_Zhang
@Anonymous, are you using 123d or Fusion 360? These are two different products.
Regarding Fusion 360, importing very big SVG to Fusion 360 sketch might have no good performance, if you only need part of geometries in the SVG, it would be better to directly create sketches inside Fusion 360.
Lori Zhang (Fusion Development)
I am using 123d and trying to import sketches from OpenOffice Draw.
Envoyé de mon iPhone
