- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I created a spline and wanted that to revolve arround the vertical Y axis.
The revolving happened without any problems, but I have three questions on that:
1.
After creating the 'revolved' body may I want to change the spline to modify the shape, so I moved the history back to the sketch where I created the spline, I modified the spline and moved the history back to the end.
But the revolved body does not update, it is still shaped using the first (old) version of the spline.
Is it not possible tho change the shape of the revolved body later on? Do I have to create it again?
2. Why the step of revolving does not appear in the history that I can edit it later on?
May this could help to recalculate the revolving if the spline changes.
3. How can I add an additional point ore remove a pint to an existing spline to change it's form?
Thanks for any help!
