Sketches, origins, and planes are not visible.in brower version.
No grid lines on my Thinkpad E460 display.
and Orings(Axis,plane) are not visible.
 Thinkpad E460 have a AMD GPU(Radeon R7 M360) .Driver is latest from Windows update.
is AMD not supported ?
JasonBrynfordJones
Hi
Thanks for getting in touch.
As we rely on WebGL it should run on almost any hardware, windows, mac, AMD, nVidia etc.  However we have seen this white screen before when the graphics card is being used quite heavily. By any chance were you running other graphic heavy programs?  Could you try again, but this time just run one Chrome tab only, with Fusion 360 browser - to see if it might be related to that?
Please let us know how it goes.
Jason
Thank you Jason.
I tried today , no other application(only chrome) and chromes single tab.
Browser version is working well.
at last time, I used both Fusion360 desktop version and browser version.
Thank you .It was solved.Cat Happy
JasonBrynfordJones
Thanks for the update, that is good to hear.
If you do find it happens again, just check what else you have running, as it might point to a graphics card memory issue. You would then need to close Chrome to free up more memory, and then start Fusion Browser once more.
Thanks again
Jason
21099mano
Observer
Observer
Hi, I have the same problem but for the fact that i have installed the software. But no sketches or axis are visible. this is the case in Autodesk inventor also. Pls Send me the solution ASAP
JasonBrynfordJones
Hi
Sorry to hear you have encountered this. It looks like it is a hardware problem.
I can only try offering some suggestions at this point:
Can you try running Fusion browser in Firefox to compare?
Close Inventor (if it is running) and then can you try running just one tab in Chrome of Fusion Browser.
Can you try rebooting and opening just one - either Inventor or Fusion Browser
Lastly, can you try uninstalling Inventor, rebooting, and trying again?
Let us know how you get on.
Jason
