How to intersect two splines?
I want to intersect two splines from top view sketch and left view sketch. but I can not find a way to do it directly. I have done two extrude of the spline in patch mode and trim the surface with each other to get an intersection edge. But I can still not extract the single curve I want. Is there a way to make this intersection line?  Screen Shot 2017-07-23 at 15.38.42.png
cekuhnen
the command is intersection curve 😉
https://drive.google.com/file/d/0Byzv_NlyKp_2WFNfX080LXNqWm8/view
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
jeff_strater
Hi @Anonymous,
This is exactly what the Project Intersection Curve command in sketch is for.  Just create a 3rd sketch, and use Project Intersection Curve, select your two existing splines, and it will create the intersection of the projection of each spline along their respective sketch normals
Jeff
Jeff Strater
Engineering Director
Hi cekuhnen, thank you for your prompt reply:) it helps me a lot:)
Thank you jeff,
I didn't know there must be a 3rd sketch, it helps a lot!
