Fusion 360 Thin Cut Feature Like SW
Message 1 of 8
Is there a way to create a thin cut directly from an open sketch (line, spline, etc.) in Fusion 360? Similar to what can be done is SW where a sketch can be used to make a thin cut into the body. This would be helpful for creating curved cuts (feature made from a ball end mill for example). The sketch would be used as the centerline for a tool path. Creating a closed sketch (with rounded ends) is way too time consuming and more difficult to modify than a single line segment. Thanks, -Art
Replies (7)
Message 2 of 8
cekuhnen
@Anonymous
I am quite sure that this is not possible the same way how you can do it in SW.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Message 3 of 8
HughesTooling
I put an idea on the ideastation for thin wall extrude it would have the option for cut but I'm not sure that's the same as what you're asking for.
https://forums.autodesk.com/t5/fusion-360-ideastation-request-a/thin-wall-extrude/idi-p/7232959
Mark
Mark Hughes
Owner, Hughes Tooling
Message 4 of 8
Thanks. That's the answer I was hoping I wouldn't get. Too bad. Maybe next release. Still hoping someone has a solution out there. It doesn't need to be exactly like SW just something even close would be useful. -Art
Message 5 of 8
HughesTooling
If you switch to the patch workspace you can extrude a surface then thicken set to cut.
Mark
Mark Hughes
Message 6 of 8
cekuhnen
@Anonymous
Hi there, @HughesTooling's idea reflects also a particular workflow in Fusion that is helpful to know.
The sketch engine is not the fastest one so I would always try to keep the sketches brutal simple as possible
and then do more work via the model tools. For example while one can fillet in a sketch I would never do it.
It keeps the sketches simpler, easier to use, faster to calculate, and surface fillets are then features we can turn on and off
unlike in a sketch were we would have to remove and then extend the sketches back to the original shapes!
Claas Kuhnen
Message 7 of 8
Thanks Mark. I was able do what I wanted to do using patch and thicken like you suggested. I guess it will take getting used to. Weird how you need to from model to patch environment. Would have been nice to do from within model environment alone. Thanks again. -Art
Message 8 of 8
cekuhnen
@Anonymous
I fully agree that today the patch model space idea does not make produce a nice workflow anymore
it would be interesting to have a quick mode switch tool
ADs idea was to keep menus relevant and focused
Claas Kuhnen
