Message 1 of 10
05:08 PM
- Mute
- Permalink
- Report
I am hoping someone can help with what I think should be a simple procedure. So I am in Design sketch. I have a simple square lets say 100mmx100mm . Then I want to add a rectangle 20mm down from the top starting on the left side and then extending as an 80mmx20mm rectangle. Is this possible without adding points or construction lines, or snap to grid which never works to my advantage when using parts of mm, or wanting from a middle location.
I am hoping there is some easy way, but have struggled with this so much. Especially of I want to constrain with dimesnions and then change the size later on, it all goes haywire.
