05:13 PM
Is it possible to create a copy of an object (including a mirror) that will change if you alter the orginal. There appears to be some linkage when you say do an extrude on multiple faces in a sketch. Then if you change it on and one of the extrudes and it changes all. But if you copy an object and then cut away part of the orginal the copy doesnt change. Quite often in my designs I have very repetative elements (like spindles in chair backs) and after I copy them I would like any change to refelect to a set. Something when I was using sketchup that was extremly useful.
