Sketch observations
Sketch observations
Sketch observations
First a big thank you to the updated Fusion 360!
I've verified that previous overconstraint sketch bugs I've come across before are fixed.  Yay!
This is awesome, now can move sketches into a component even after a body is made from it!
The driven dimensions are great to show dimensions.  If choose a driven dimension for a dimension that does not have a driving dimension, then dragging the end points around to change the dimension updates the driven dimension in real time, which is cool.
The constraint cursor icons are great, especially to let one know when in constraint application mode, which was an issue before in accidentally applying constraints and what not.
A nice optional feature to have constrained line segments change color.  Should be very helpful.  I've noticed the color change is not for a fully constrained line segment, but something that's probably more useful.  Specifically, it looks like can think of a line segment as lying on a rail/ray that is infinitely long in both directions.  The line segment that lies on the rail, will change to constrained color when its rail is fully constrained, meaning the infinite rail is fixed in orientation/angle, and also laterally (cannot move side to side).  So if a line segment changes to constrained color, it may still be able that its two endpoints can slide along its fully constrained rail, if more info is not given to prevent that.
And all kinds of cool other things.
A few little flukes I noticed are that in the regular Light Room environment, the constrained line segment color is black, again being the same as the dimension lines, which can detract from the mind being able to easily process the sketch geometry.  Yet when go to my fallback to differentiate these different types of lines, the Grey Room, it turns out the color for unconstrained line segments is quite similar to projected geometry -- pinkish/purplish.
Another thing I noticed is when click on a line segment from another sketch to project it into current sketch, the now projected purple line is often obfuscated by the other sketch line, not being able to see it until turn other sketch off.  This can make it confusing to know/keep track of if actually projected desired lines.
A final strange little fluke is when project a point so turns purple, then change environment, say from Grey to White room, the purple point changes to just a fuzzy dark point or some other crazy color depending on environment.
But all in all a very exciting time to be using and teaching Fusion 360!
Jesse
prichas
Thanks for your feedback.  I was able to duplicate the same behavior you described.
You are correct, when switching environments, the projected endpoints turn dark grey in color.  As a test, when reopening the file,  it corrects itself.
I will report these issues to get resolved in a future update.
Shayne
Remy18
I would like to comment the constraint color of a sketchline segment endpoints. If for example a line with a horizontal constraint is defined for a certain diameter, the color is changed to be fully defined. Still the endpoints are under-defined without a dimension or fix constraints. The color of these endpoints should show a different color like a fully defined line with fix constraints(line E) or projected/intersection line segments.(line A). Like the screenshot shows, the endpoints of line F,C and B are white colored suggesting to be full defined, but there are not.
At complex sketches the color of sketchline endpoint could give a better overview of under-defined endpoints.
HughesTooling
The other programs I've used use 3 colours, well 4 if you count going red when the sketch is over constraind. I've copied this from another post I made last year
Here's an example from another program where you get a colour change when the size is constrained but position isn't and a colour change when a sketch is fully constrained.
Also a rectangle with one point constrained to the origin shows unconstrained.
When one dimension is added it shows 1 line fully constrained and 1 line as position unconstrained.
Mark
Mark Hughes
Owner, Hughes Tooling
