- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there. I fairly new to Fusion so I'm still learning a lot.
I have a sketch object i would like to mirror. I have inserted a dxf into an existing sketch and for some reason it is a mirror image of the way i saved it when i exported it as a dxf from a different project in Fusion.
No problem right? Edit sketch, select sketch objects to mirror, select mirror command from sketch drop down and select line to mirror with.
Only problem is, as soon as i select the mirror command, the sketch object i want to mirror grays out and i cant select it while in the mirror command.
Note: I can mirror other sketch objects within the same sketch.
