After creating a new Sketch, I copied another sketch into it, then tried to move it using the horizontal arrow. It behaved erratically, moving either up or down as well. This is shown in the screencast.
I tried saving the project, restarting the computer, and running Compute All to check for any errors. Didn't help. The Move dialog does not show any change of position in the Z axis, although it has moved in Z as well as X direction.
Tried it again in another new sketch, but with just a 2 point box - the Move tool worked OK there. I've copied sketches from one to another many times before without issue, so this has me puzzled. Anyone have a suggestion as to what could be happening?
Solved by jeff_strater. Go to Solution.
there is something strange going on here, certainly. I don't see quite the level of movement that you are seeing, but I do get a few jumps. I'll investigate.
I was able to reproduce this by just copying the sketch to a completely new design. This is just some kind of solver weirdness, I suspect, so I sent it off to the sketch team to investigate further. The bug is FUS-82707
That might explain an earlier problem I have with that sketch - SailGP added a transom extension to the hulls, so I tried to Loft that sketch with another, "Section Transom Extension". I needed a couple of Rails, but despite Loft saying the top rail doesn't touch one of the profiles, it shows Coincident Constraints to both in Edit.
I would expect to see a red blob telling you which end of the rail is incorrect, when you get that error.
Did you Project > Intersect the Splines to the Rail sketch?
Is the Rail sketch a separate 2d sketch?
Turn off Chain Select.
Couple of things that normally bite.
Might help....
Chain Select will allow the rail to be joined to a profile curve, and send the Loft tool into orbit.
I would not / have not used Include 3d Geometry for this, it causes your sketch to become a 3d sketch, Fusion is a lot happier with many 2d sketches. Project > Intersect is more appropriate, wont say right or wrong.
Might help....
What would be "best practice" to replace the corrupt (?) object in the sketch? I did something like that once before because I made a mess of it - deleted the object and recreated it in the same sketch - and later found I had a heap of errors in subsequent actions. I did resolve the errors, but it took some time.
Is there a better way to do this?
That's it in a nutshell.
Much better to edit than delete, and even then somethings will break but not as many.
Might help....
