Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Can I fix sketch automatically?
3 REPLIES 3
SimonPlatten
229 Views, 3 Replies
I have a sketch:
I want this to be filled so I can use it to extrude, however there must be some tiny gaps prevent it from being filled, is there any tool that will complete this for me?
3 REPLIES 3
SimonPlatten
in reply to: SimonPlatten
Completed it now.
g-andresen
1. are all the lines are in the same sketch?
„Divide and conquer“
2. unfix the green lines
3. create a line across and move it > check if/where a closed profile appears
4. create a second line and delimit the area of the gap
günther
@SimonPlatten wrote:
Completed it now.
I would never use a series of curves like that in my design.
I would use only as reference in creating a single curve that matches the reference well within an manufacturing tolerance.
If you had Attached your file here I could have used actual geometry rather than a mere picture.
