I have a sketch:
I want this to be filled so I can use it to extrude, however there must be some tiny gaps prevent it from being filled, is there any tool that will complete this for me?
1. are all the lines are in the same sketch?
„Divide and conquer“
2. unfix the green lines
3. create a line across and move it > check if/where a closed profile appears
4. create a second line and delimit the area of the gap
günther
@SimonPlatten wrote:Completed it now.
I would never use a series of curves like that in my design.
I would use only as reference in creating a single curve that matches the reference well within an manufacturing tolerance.
If you had Attached your file here I could have used actual geometry rather than a mere picture.
