sketch menu issue
sketch menu issue
jezek.jaroslav
sketch menu issue
jezek.jaroslav
sometines I face strange behavior  if I right click my sketch to open the menu. I don't see the correct one with all the sketch options. Instead I see the one like on the picture attached.
To get rid of this I need to either re-open the part or I have to edit the sketch prior the last one, close it and than I get the correct menu on the last sketch. (I know it's a bit confusing) 🙂
Looks like there is something selected that is not the sketch. But I select the sketch for sure.
Anyone facing the same issue ? Any suggestions ?
Thanks a lot
JJ
g-andresen
This is a known problem.
Solutions:
1. Move the cursor to the start of the timeline (several times) and then back to the end.
2. Switch back and forth between elements in the browser.
günther
