- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've got a sketch, small & simple at this point.
I've extruded a couple of things.
Then edited the sketch; added a rectangle. (Then another few lines for testing)
The newly-added rectangles & lines do not create profiles anymore.
I'm quite baffled how this is possible and wondering if anyone has any idea...
The sketch is fully defined,
3d sketch is off (and was off, I did not touch it)
there are no selection filters active
Edit: attacked the f3d file
Yet I can't use the new rectangles & lines for extrusion. There seems to be no profile created by them.
I've attached two sample images to illustrate the situation, hopefully it helps.
Thanks for any ideas in advance!
