Door panel help:-)
Door panel help:-)
potlsnekkeri
Door panel help:-)
potlsnekkeri
Hey, I'm going to make a panel for a wooden door.
how can i make that rectangle become a pyramid?
https://a360.co/3WW2Qtr
anoop9K98K
You can either use the loft function by creating a point at the particular you want it to be.
OR
You can you extrude function with taper angle
Give me a shout if you want me to show you.
Anoop
potlsnekkeri
yes can you show me
JamieGilchrist
Hi @potlsnekkeri
As @anoop9K98K says, create a loft to a point.  here I created the point in the sketch where the rectangle is for the door. Create an offset plane, a new sketch, and project the point. use the point as the second side of your loft.Screenshot 2024-08-09 at 11.48.59 AM.png
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
CGBenner
@potlsnekkeri Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
