Need help in sketch or 3D sketch and sweep
anoop9K98K
anoop9K98K
Hi all,
I want to connect a coil with a straight piece coming through the middle. Fig is attached below.
As shown I am struggling to connect the straight line with the coil with a smooth curve, where I can alter the fillet. I have tried a few method. I have got into a brain freeze now.
Can anyone give some ideas. I have attached the file below.
Hope to hear from you all soon.
Many thanks
Anoop
@johnsonshiue
@davebYYPCU
wersy
Quick and dirty.
davebYYPCU
Use a 2 point spline, connect both sketch items, and at each connection, constrain Tangent.
Use the Tangent handles with the Move Tool, to adjust the curvatures required, if default does not suit.
Might help…..
CGBenner
@anoop9K98K Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
