Sketch Dimensions and Special mouse
So basically I have a mouse with numpad on the side.
I use this to insert dimensions and values without having to move my hand over to the keyboard when 3D modelling.
However there is one very fustrating thing about fusion 360 sketch dimension:
When I go to lets say make a line and I have the option to dimension it, whenever I type a value, I have to keep the mouse 100% still until I hit enter. If I move the mouse the slightest, the value will dissapear and I have to try again. This is very tiring because it makes it even harder to dimension than actually using the keyboard!
Any idea how I can avoid this from happening?
Best regards,
Lasse
g-andresen
Even if that's not what you want to hear,
I assume you don't change that as long as you use one of these mice.
günther
whittakerdw
When you type in a value do you not get a yellow lock beside the value?
If not, do you get that lock when you use the keyboard to type in a value? That lock locks in the value entered so you are free to move wherever for the angle of said line.
jessecockayne
Community Visitor
Community Visitor
If I don't get the lock, how do I make it show up. And let's say I do get the lock, but it seems to make no difference if the lock is there or not. If the mouse moves even the slightest bit, it automatically erased the value I am trying to type in, and replaced it with the grid coordinates of the mouse cursor. Example: I got to make a rectangle. I click the start point, I can now either click a second point on the grid OR I "should" be able to take my hand off the mouse, then type the length of one side, then hit the tab key and type the length of the other side, but what ends up happening is I let go of the mouse, start typing a length (let's say 150) I press the number 1, then the number 5, then my mouse moves 1/1000 of an inch on my desk and both the 1 and 5 are erased and replaced with whatever size the cursor is at right now.
