sketch constraints
sketch constraints
JYZMT
Message 1 of 8
sketch constraints
JYZMT
Can some one tell me why parameter Test_B can not be changed? I can't see why its being constrained?
Replies (7)
Message 2 of 8
@JYZMT
Isn´t that very similar to the problem you posted here?
https://forums.autodesk.com/t5/fusion-360-design-validate/sketch-problems-over-constraint/td-p/76854...
To quote your last entry there: "....It seams ok with circles, as suggested earlier, but not with semi circles...".
That´s exactly the same problem here (I tested it with circle/tangent -> no problems). I suppose that it might be a bug in the sketch-solver.
Maybe you should post this example in the "support" area with a more specific description (like your quote "works with circles, but problems with arcs") - you might have a better chance to get a feedback from Autodesk.
Just an idea.
Manfred
Message 3 of 8
TheCADWhisperer
I couldn't find what exactly was wrong with the sketch - so I tried to reproduce the issue in Autodesk Inventor Professional.
Everything worked as expected in Inventor.
If you are a student - you can download Autodesk Inventor Professional for free from Autodesk Education Community.
Message 4 of 8
JYZMT
Thats funny, I thought I had posted it in the support forum??? I'm sure it was their earlier because I was looking at it against the other topics, which are still in there? strange. Either I'm losing it or it was moved.
I tried posting again (my intention within the support forum) because last time we put it down to an old rouge file, but this was a new fresh one and it still went wrong.
Thanks for checking this @TheCADWhisperer I also can't understand why its not working, and this is the point. this is a simplified version of models I need to build, and I really need to understand what is wrong with my methodology, so I can build it differently. If there is a problem in the way I've defined in terms of logic, then I just need to know... but as far as I can see, it should work?
The circles method is also going wrong when I tried a few things, so that's not the solution. BUT I have had success with defining the circles (and arc) using a radius dimension, as opposed to a point to point dimension used in the file. Its as if it gets stuck when it tries to change the overall width.
Message 5 of 8
HughesTooling
Drawn and constrained in a slightly different way seems to work. File's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 8
HughesTooling
Just experimenting with your original sketch and just dimensioning the arcs with a radius rather than from an edge fixes it. After deleting your dimensions I needed to try and drag an arc centre which made the sketch jump and correct itself then add the radius dimension.
Mark
Mark Hughes
Message 7 of 8
jeff_strater
Thanks, @HughesTooling for the suggestion.  I will pass the original design to our sketch team to investigate more fully why it fails.  It could be a bug.  Thanks for sharing the design, @JYZMT.
Jeff
[edit] the bug on the original model has been filed as FUS-37937
Jeff Strater
Engineering Director
Message 8 of 8
JYZMT
Thanks, this does seam to work. But Its made me really question the robustness of sketches, which should be super stable for confidence in this software. I can't see any errors in the logic of what I was doing before, and Its made me very nervous as I define new models and sketches. Basically I feel like I'm designing on eggshells; I'm testing every parameter with gritted teeth to see if it glitches, and I've lost loads of time unpicking models I thought were working. Thanks for your help.
