Sketch problems - over constraint
JYZMT
Message 1 of 17
JYZMT
Help,
Can anyone have a look at the attached file and tell me where I'm going wrong?
Variable X and Y lock down?????, it gives me a red dimension error. I can't see why they are locked? they should not be?
Replies (16)
Message 2 of 17
@JYZMT
After opening your file, I got this:
-> "Modify" -> "Compute All" fixed the problem.
Message 3 of 17
JYZMT
Thanks. But why is it doing it. When ever I make changes to the overall dimension, the thing seams to fall over. It must be the why I constrained the sketch, but can't see where.
Message 4 of 17
JYZMT
I can get the width to work now, and I can get the height to grow parametrically, but as soon as I drop the height, it freezes up.
Its something to do with the semi circles because with out them it works fine. Why would they constrain it?
Message 5 of 17
TheCADWhisperer
Before I spend significant time on this - can you give a bit of information on why you are up to dimension d670 and some information about your Design Intent?
Message 6 of 17
JYZMT
ah yes... d670. This is because previously I had a large complicated model. Arrogantly, I did not bother playing with the key parameters early on because I thought it would all work fine. I got miles down the road, tried changing a few key things towards the end and it got very messy. I've spent 3 days unpicking the whole thing trying to find out whats constraining it. I've stripped everything back, but its the same file.
The semicircles are because the object is being CNC pocketed, and I was looking to include the dogbones in the original sketch and extrusion, rather than try and add them all later.
Message 7 of 17
TheCADWhisperer
Imagine the detritus left behind by deletion of so many trials.  Lots of 1s and 0s the software wasn't sure if it should retain or not.
I consider my first attempt (or 2 or 3) to be only an exercise in understanding the geometry.  Then I create a clean and robust model.
I have found that it is almost always faster to start over from scratch using what I learned from earlier attempts than to try to put lipstick on a pig.
Interesting sketch behavior though....
Message 8 of 17
eellenburg
Replace the arcs with circles and you can resize up or down without errors.
Message 9 of 17
JYZMT
Thanks. So you think its just because of the history of the file? I'll start afresh and see how far I get.
Do you know a why to grab parameters from another file? Other wise I have to set them all up again.
Message 10 of 17
TheCADWhisperer
@JYZMT wrote:
... Other wise I have to set them all up again.
I only saw a handful?
Also, I would make use of obvious symmetry about the origin.
Message 11 of 17
JYZMT
Thats because I stripped them all out when I stripped the file back. I guess there is no way to import them then?
Message 12 of 17
TheCADWhisperer
There might be - I don't know.
I don't use Fusion - I use Autodesk Inventor where it is easy to export/import parameters with Excel.
Message 13 of 17
HughesTooling
There's a parameter IO plugin on the app store.
https://apps.autodesk.com/FUSION/en/Detail/Index?id=1801418194626000805&os=Win64&appLang=en
Mark Hughes
Owner, Hughes Tooling
Message 14 of 17
JYZMT
Thanks. I'll try and rebuild from scratch and let you know how it goes
Message 15 of 17
JYZMT
I re built in a fresh file, and it does indeed seam to work. Annoying I've lost 3 days to a bug, but lessened learned. Start fresh every time.
Message 16 of 17
JYZMT
And now its happening again. Something happens when you use semicircles, with coincident points and fixed diameters. I can't understand a logic behind this. Can anyone from auto desk explain why the model is being constrained? Thanks
Message 17 of 17
JYZMT
It seams ok with circles, as suggested earlier, but not with semi circles.
