Simulation stuck at 1%
35 REPLIES 35
Message 2 of 36
reynante_gabriel
2735 Views, 35 Replies
Hello, I have problems performing simulations on Fusion360 the resolution of the simulation remains stuck at 1% for hours without giving a result.
Do you know where this problem came from?
- My Fusion 360 is updated
- I tried it on online https://fusion.online.autodesk.com but still the same.
- I also tried it with another computer but still stcuk at 1%.
- There is no status of "fail"
- My internet was stable
Thanks!
35 REPLIES 35
Message 21 of 36
egcolby
in reply to: reynante_gabriel
And another occurrence of this. If anyone can have a look at why my account seems to be stuck at 1% I'd be very grateful.
Sorry, but this shows how Cloud based simulation can really suck.
Message 22 of 36
Hi @2530386 @dmgutz1 @egcolby
I asked the engineering team to clear your simulation cache. I'll keep you posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 23 of 36
I am also having the same issue. All of my cloud simulations are getting stuck at 1% for the past few days. Is there any way to clear the upload queue myself?
Message 24 of 36
Hi @2530386 @dmgutz1 @egcolby @baxter.gonzalez
Engineering cleared your ques. Please try to rerun your simulation.
Thanks for your patience.
-Dan
Dan Banach
Message 25 of 36
egcolby
Hi Dan, Thanks that seems to have sorted things out.
Message 26 of 36
I seem to have the exact same issue. Simulation stuck at 1% for hours.
Can someone look at this?
Message 27 of 36
Hi @ch.mousset
Engineering cleared your que. Please try to run the simulation again.
-Dan
Dan Banach
Message 28 of 36
hi @dan.banach,
the issue doesn't seems to be resolved. Can you try again?
Message 29 of 36
Hi @ch.mousset
A change was made to this service a couple days ago that should have fixed these issues. Can you please restart Fusion and try running the simulation again and let me know how this goes.
Thanks for your help.
-Dan
Dan Banach
Message 30 of 36
dan.banach
in reply to: dan.banach
Hi @ch.mousset
The team looked at your que and they didn't see any issues. Please resubmit the job and give it time to get in the que.
If after an hour, the job is still in the que, do NOT cancel the job. and reply to this thread. This will help engineering.
-Dan
Dan Banach
Message 31 of 36
Iyan.A1
I am also having the same problem my job sends, but the simulation is stuck at 1% please help
Message 32 of 36
dan.banach
in reply to: Iyan.A1
Hi @Iyan.A1
How long has the job been in the que? Have you tried to cancel the job and then restart it?
If so, please leave the job in the que and let me know. Then I’ll ask the team to look at your que.
-Dan
Dan Banach
Message 33 of 36
Iyan.A1
I have tried to cancel and restart, no luck. I have left it in queue for an hour too.
Message 34 of 36
Iyan.A1
Message 35 of 36
Hi @Iyan.A1
The team looked at your que and didn't see anything. Can you please restart Fusion and submit the job again.
Can you confirm that you're on the latest version of Fusion 2.0.18719? On the top-right corner of the screen click on the ? > About.
If the issue persists, please attach your log file for Fusion. Here are instructions on how to obtain the log files.
  1. Start Fusion.
  2. On the top-right corner of the screen, click on the ? Icon > Support and Diagnostics > Diagnostic Log Files
  3. In the Diagnostic Log Files dialog click Open File Location
  4. Attach the zip file to your reply "Fusion360DiagnosticLogs.zip"
-Dan
Dan Banach
Message 36 of 36
Iyan.A1
Thank you the problem has been solved
