Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
show drawing sheet name on sheet?
6 REPLIES 6
worknstuff
341 Views, 6 Replies
hi, has anyone found a workaround to show the drawing sheet name on the sheet?
i'm just using a manual text box per sheet right now...
6 REPLIES 6
g-andresen
in reply to: worknstuff
Sheet Name is currently not available.
Take a look at the Roadmap.
günther
ClintBrown3D
Hi @worknstuff
For right now, you could use a parts list.
As @g-andresen mentioned, the public roadmap shows what we are working on. We do have some improvements for title blocks planned for a future build (have a look at Usability [top right]).
johnTVYKW
in reply to: ClintBrown3D
worknstuff
thanks for the suggestion. however i am using selection sets in a an assembly to build 20 skus from common components, so unfortunately, no component is specifically linked to a sku.
worknstuff
on another note, many of these common components are also derives. would be helpful if derive brought across thread data into drawings. (appreciate thread data in drawings is recent, just putting it out there for the next step).
This was three years ago. Have you achieved any advance?
