Sheet metal flange tool weird new behavior - Fusion
Miha-M
Message 1 of 23
Miha-M
Why it is behaving like this. It suppose (and it used to) to make one continuous sheet metal piece bent 5 times.  Now it treats every polyline se a separate body?????
Anyway to make it behave like it used to? Treating all the connected polylines as single piece and applying bends at connections as well. fusion.jpg
This post has been edited due to: @heather_tracy added the product to the title to help more users find this topic via external search.
Replies (22)
Message 2 of 23
Miha-M
EDIT:
It is even worse.  It creates a single body sheet metal part that it then fails to create flat pattern for,....  😵
Message 3 of 23
g-andresen
works fine here
Please share the file for reply.
File > export > save as f3d on local drive > attach to post
günther
Message 4 of 23
Miha-M
Here you go
Message 5 of 23
g-andresen
There is obviously an error in the sketch in the connection of the lines at the origin, but it could not be corrected in the sketch.
Therefore, I created a new sketch that produces the expected result.
(view in My Videos)
günther
Message 6 of 23
Miha-M
I get that. But up until now you did not have to do it in one go. Lines were automatically merged to one polyline (so to speak) you could start in the center and then added line. I do it like this all the time because a lot of times i change / add sheet metal profiles afterward.  This effectively prevents changing base sketch line once you close the tool. It should not do that. This severely limits what this tool can do.......
Message 7 of 23
g-andresen
@Miha-M  schrieb:
Lines were automatically merged to one polyline (so to speak) .
However, this was not done correctly in your case. That is why I deleted the lower part of the sketch in this screencast and reinserted it.
(view in My Videos)
I was unable to reproduce the erroneous behavior in several attempts.
günther
Message 8 of 23
Miha-M
So what did I do  wrong?
why doesnt merge the lines if merging point is in coordinate origin?  If i add the line on the opposite side it works just fine....
Message 9 of 23
Miha-M
edit:  im out of office now...
Message 10 of 23
Miha-M
here is a video
Message 11 of 23
g-andresen
In some tests, I noticed that the phenomenon only occurs when the profile starts at the origin and another element is added there.
If you create the primary profile without binding it to the origin, you can add elements and, if necessary, subsequently bind the docking position to the origin using a constraint.
Perhaps @johnsonshiue can take a look at this.
Günther
Message 12 of 23
johnsonshiue
Hi Folks,
I took a quick look at this design. I have seen the behavior before. It seems to be related to the open profile recognition. Creating a surface from the same sketch may lead to the two separate surface body also. Somehow the horizontal line (150mm) is constrained to a point (probably a corrupted projected origin?), not to the end point of the vertical line. As a result, it leads to a split. If I delete both the horizontal line and the vertical line, and recreate them, the profile will be properly recognized.
I suspect this is a corruption case. If we can reproduce it from scratch, it will be very helpful to finding a fix.
Many thanks!
Software Test Engineer
Message 13 of 23
TheCADWhisperer
@johnsonshiue
@Miha-M
I deleted the Coincident Constraints and moved the lines away from the Origin. (I did not delete the lines.)
I then applied a single coincident and left them away from the Origin, observed the same unexpected behavior.
Edit: I then tried deleting EITHER the vertical line or the horizontal and replacing.  Replacing EITHER of these lines returned to expected behavior.
Message 14 of 23
Miha-M
So i tried this at home on my hobby license fusion. After updating to the latest version this behavior occurs. Dont know which version i was on before update. i kind of resist updating if not necessary.  So it must be a bug in latest update?
Message 15 of 23
GC_CC
Hello, I have the same problem. See https://forums.autodesk.com/t5/fusion-design-validate-document/changes-in-sheet-metal-flange-tool/td...
It is indeed a bug and will hopefully be fixed soon.
Message 16 of 23
Miha-M
So i moved the lines out of the origin and join them, then move the back to origin. An this happened
Message 17 of 23
Miha-M
So how log does it usually take to squish a bug like this?
Message 18 of 23
Miha-M
I see this hasn't been resolved in last update
Message 19 of 23
Miha-M
Still not fixed on
2606.1.36 x86_64
Message 20 of 23
johnsonshiue
Hi Miha,
I am sorry I don't know why it has not been resolved. I thought it was. Maybe I misunderstood the issue to begin with. Are you trying to merge the new Flange to the existing one? The panel shows it is creating a new body.
Many thanks!
